Thruster87 Posted August 12, 2009 Posted August 12, 2009 The floats-on-a-swing-arm senders are a legacy product from cars and other vehicles that go back a very long way. Making these things really accurate in more\ than one place is a bit fussy. Years ago, we crafted an electronic signal conditioning board for the Bonanzas and Barons that allowed dead-on calibration of empty and full. All other readings across the scale simply fell where where the physics of the sender dictates. The physics of these devices are affected mildly by linearity of the wire wound sensor resistor (usually within 5% of true) but a whole lot by trigonometry of the swing arm and tank geometry. But as you've already recognized, the one level you really want to be accurate is the empty point. For this you can do some things with series calibration resistors and/or bending the float arm on the sender. This CAN be a tedious, trial-by-error activity. If it were my airplane, I'd probably craft a microprocessor based signal conditioner that would allow me to take readings at 5% increments from empty to full and generate a lookup table that converts as-installed sender (transducer) readings into real numbers. The BEST way to watch full levels is with installation of a "dip stick" style sensor at the low fuel warning level (generally 1/4 to 1/3 tank). Consider devices like this: One of these stuck through the tank wall at the warning level will light a lamp on the panel at the desired fuel quantity with no risk for drift of calibration. See: http://www.gemssensors.com/content.aspx?id 82 This is the no-brainer, dead-nuts accurate low liquid lever sensing method I know of. Capacity fuel gages with processor augmentation are also easy to calibrate . . . but I think I could get by with no active fuel gaging other than a set of optical level detectors cited above. [ATTACH]8555.vB[/ATTACH] by nuckolls.bob(at)aeroelect
