Guest micgrace Posted May 27, 2006 Posted May 27, 2006 Hi everyone Something that could possibly be a potential very nasty problem. Whether this has been the cause of any accidents I can't seem to find a reference to. Maybe someone has come across it. Some ultralights are fitted with an engine fuel pump as well as a parallel electric fuel pump. With both connected just foward of the outlet of the engine pump. WhereI tend to voice a bit of concern, is the separation or breakage of either fuel line while one remains operative. (i.e. fuel still getting to engine) I believe it would be quite possible for the engine to be running normally with the pilot unaware the fuel is rapidly disappearing from the tank (into engine bay, cockpit or whatever). Especially in those aircraft where fuel level cannot be easily seen. The consequences are possibly an inflight fire or no fuel. In doing an inspection I would STRONGLY reccomend to check the fuel lines (hopefully aircraft grade) , cracks, swelling, (especially around clamps)age, aircraft clamps and barbed fittings. correct routing of lines. Correct use of grommets. To check for cracks bend hose back on itself, if in doubt change. Also, while on the subject I have noticed some use of Automotive paper fuel filters on 2 stroke engines. The oil and fuel mix reacts with the resin in the filter, swelling the fibres plugging it. Nylon / brass type screens only Micgrace :) what you don't know will get you
Guest TOSGcentral Posted May 27, 2006 Posted May 27, 2006 The Thrusters have a semi dual system standard. Single outlet from tank. Splits into main fuel line and the other to the electric boost pump. Then both lines have clear view filters. Then they conjoin again and a single line leads up to the engine. Simple and effective - except owners get excited about the plumbing and some really weird results have been seen to happen. Drawing a mud map on a piece of paper and then putting it into practical use effect does no end of good!
Guest micgrace Posted May 27, 2006 Posted May 27, 2006 Right on Tony Do not take chances in this area. If in doubt ask. I do not know about the Thruster layout, however Tony's the expert on them>but this set upwas commonly used on early drifters and such which have (more than likely) suffered incorrect mods. I'm sure I seen a dual pickup used on a chinook 95.10 (fuel tank mounted in ex passenger seat place)as well. even a worse idea. By the way with rotax 2 stroke you DO NOT run engine/electric fuel pump in series. It will create excess fuel pressure and flood the engine. Micgrace :)
Thruster87 Posted May 27, 2006 Posted May 27, 2006 I've not exprienced any problems with my Thruster which is setup in series. Cheers Alan
Guest micgrace Posted May 27, 2006 Posted May 27, 2006 A few more notes The use of in series fuel pumps is a trick used in high performance engines to 1. increase the overall fuel pressure 2. deliver an increased volume of fuel. Think about this statement for a moment. Fuel pump A supplies fuel at a certain pressure. which is supplied to fuel pump B which no longer has to do the work of pulling fuel from tankas well asraising the fuel pressure to an acceptable level. The end result is increased pressure and flow. When this system is used on high performance carby equipped engines a fuel pressure regulator is used to prevent flooding due to excess pressure. On injected engines a pressure regulator is used to lower the load on the efi pumps at idle. OK so someone will say but that doesn't relate to aircraft does it? But think about it before jumping to conclusions. This is where confusion arises. The reason a parallell system is used in some aircraft is somewhat different to this. This is to assist with fuel flow with a high angle of attack generally associated with takeoff climb. Think for a moment what happens when an aircraft with a gravity supplied fuel tank climbs. The tank is now lower than before, (compared to the engine)hence the fuel pressure and flow reduces. By using a electric fuel pump in parrallel sufficient fuel will be supplied. This effect would certainly apply to a thruster. Other arrangements would certainly benefit from it to ensure no shortage of fuel flow (not increased pressure, although the two are interconnected) for takeoff. Hence the parallel design. Since most aircraft engines are fitted with a float type carburettor it is quite possible to exceed the fuel inlet pressure which takes only a small increase to actually push the float in the fuel and flood the engine. At wide open throttle with electric fuel pump on a pilot would probably not notice any flooding. BUT at around idle it is quite possible to flood an engine. A pilot who turns the electric pump on for climb out then turns it off for cruise would likely be none the wiser. I have witnessed this effect and it takes a couple of minutes to develop, the effect is not instant bit like leaving the choke on too long. All the pilot seems to think he's left the choke on, need new needle/jet. Fuel consumption too high, or whatever pet theory they have without identifying the real cause. The pilot then "clears" the engine and everything seems to be fine. Needless to say, operating in this condition will not help the engine. Fuel wash will remove oil from cylinders/pistons etc, create excess carbon, jam rings foul plugs. Like all good things this design MUST be correctly maintained, installed and operatedhence the earlier post. Beware. Micgrace :)
Guest micgrace Posted May 27, 2006 Posted May 27, 2006 The problem with an unauthorised change on the Gazelle arose from removal of engine pump and substitution with an aftermarket fuel pump. No doubt this came from a misguided attempt to save money. The person who did not know any better removed the plumbing from the parallel fuel circuit effectively boosting the inline pressure as such this jury rigged idea would have to be run full time instead of the usual practice. i.e direct from wing tanks to header tank then through the aftermarket electric fuel pump straight to the carby. If the pump was not on this provides a restriction otherwise so pump would have to run full time. There is (from memory) a fuel return on the engine pump (I'll check the parts catalogue to be sure) This acts to reduce pressure if the flow dimensions are carefully matched to pump output.if anything is any different, I'll make a new post with any corrections. This is the simplest way for a designer to attend to this design problem. No moving parts to control fuel pressure. (= safer) The Gazelle of course has a boost pump for climb out, which is then turned off. It forms part of the takeoff/landing procedure. 4.5 NORMAL PROCEDURES & CHECKLIST (extract CA-25N Flight Manual) (F) Check before Takeoff: 4. Fuel Pump Switched on. (even marked red) Electric fuel pump plus engine pump fitted from factory on R912 These comments equally well apply to 4 stroke (carby) engines. Although it is safer for a spark ignition engine to run too rich, compared to too lean, though not ideal over the long term. The opposite condition (rich = death to engine) applies to diesils (yes they are made for aircraft) The idea of the post was to bring to everyones attention the necessity of fuel hose inspection, however, this has uncovered another problem that people have created themselves by deviating from manufacturers plans without the prerequisite knowledge to do so. There are other ways to increase flow to engines. The simplest is to increase the size of the fittings. I remember seeing something from TOSG about the exact same problem in Thrusters (i.e. fuel line diameter too small) Tony can comment on this I'm sure. Of course to be legal (95.55 factory) even this change must have Reg 35 approval. The point is, a backyard "fix" can seriously endager safe operation if you do not have the prerequisite knowledge. I'm not going into a full theoretical debate on this issue. It took me a full engineering degree to learn about such things. Micgrace :)
Guest micgrace Posted May 27, 2006 Posted May 27, 2006 A slight correction to the above. The fuel return line (not on pump)uses a separate fuel pressure regulator. This style of arrangement is very German and gives very precise control, however adds to cost. It is possible to overpower these devices with too large a pump (or simple fuel return). I have done very little work on R912 so someone who does could clarify for me . Thanks Micgrace :)
Guest carlsnilsson Posted May 27, 2006 Posted May 27, 2006 Surely the Skyfox Gazelle installation is a series system, i.e. the electric fuel pump is in series with the mechanical, which is why you can/should switch it off out of the circuit? This is fundamentally different to the parallel system with which this thread started. Carl
Guest micgrace Posted May 27, 2006 Posted May 27, 2006 I'll have a proper look at the plumbing on a Gazelle and confirm it one way or the other. And I'll post the results. There is no reason it couldn't be in series as the r912 does use a proper fuel pressure regulator (although on the return line). Although to be fair I never paid much attention. All I do is follow the exact layout by the manufacturer when doing repairs. Micgrace :)
