Forgive me if this has been covered before, but I am new to this site.
I will almost certainly commence building a Zodiac CH 601 XL in April.
I am aware there are quite a number of Zodiac aircraft in Australia.
Is there enough interest to start a forum for this type of aircraft?
G'day Gavin,
Not sure if you have noticed, but I have put a message in your Inbox.
regards
Case
Hi Gavin
Personally i know of two under construction in Adelaide and another couple that have been flying for sometime. If you go to http://www.sportaircraft.org.au
and browse to the photo's of aircraft and contruction to check out John
Partridge's 601Xl you surely will get excited about John's project.
Regards
Ed
  • 3 weeks later...
Hi Gavin Personally i know of two under construction in Adelaide and another couple that have been flying for sometime. If you go to http://www.sportaircraft.org.au
Regards
Ed
Ed I think you will find that this the sportaircraft site is now defunct. I made an enquiry some time ago about an aircraft advertised for sale. It worked OK then, but since going back to this site several times in the last 2 weeks, I find that the site cannot be found. If you have an update, then that would be helpful.
Thanks
Galpin
