Guest des walsh Posted April 28, 2009 Posted April 28, 2009 g'day, appreciate any comments on sennhiesser hme 95 and altronics noise reduction C9069A headsets. thanks-des
Guest drizzt1978 Posted April 28, 2009 Posted April 28, 2009 I did some quick research on Sennheiser, when i purchased my headsets, Nobody seemed to have much too say in Australia about them. Go figure! They are awesome for muscians, I have a set of hd251 headsets, i use them to listen to music when i play the drums. You can hardly hear the drums of the music blasting away. I ended up getting Zulu 20xlc. You can read customer reviews on lots of headsets here: LightSPEED 20XLc ANR Headset - MyPilotStore.com And thats the link for my headset...
Guest pelorus32 Posted April 28, 2009 Posted April 28, 2009 G'day Des, I'm just in the process of doing a review on the Recreational flying/Clear Prop (that's this site's pilot shop and funds the site) ANR Headset. I should have a review early next week. Ian can update you on price but it should be very competitive. Regards Mike
Admin Posted April 28, 2009 Posted April 28, 2009 The Recreational Flying 1000 ANR Headset is still several months away as after Mike has done a review we will take one over to an Avionics technician to pull apart and provide a written report on anything they think could be improved as these will have a full 5 year clean swap warranty. Once we get the Tech's report we will go back to our manufacturer with any recommendations (if any) and get them to change our requirements to suit but at this stage we are looking at a mere $399 for a full ANR headset.
Guest drizzt1978 Posted April 28, 2009 Posted April 28, 2009 Hey Ian, sounds like they will be in time to give to my girlfriend so she cant be jealous that i have the fancy ones......Dam i hope they dont work better than mine at half the price!!!! or else she gets the expensive ones ;-)
Tomo Posted April 28, 2009 Posted April 28, 2009 I have a set of these and have had to relegate them to the passengers set. From day one they produced feedback squeal on PTT. I had a technician familiar with them take a look however he could not come up with anything to solve the problem. The reason I couldn't send them back was they worked fine in another aircraft I tried and as the tech said they test fine. Interestingly I've noticed that I don't get the feedback if the voltage is down a bit as in before starting engine. I look forward to Clear Props new addition down the track.Cheers Dexter You may wan't to fit a Ferrite Rod conductor things around your com wire on the aircraft... Available at most electronic places, Ie. Dick Smiths Also It could have something to do with the alternator on the aircraft (electronic feed back). If it only does it when the engine is running, I can nearly guarantee you that's what it is...
Tomo Posted April 28, 2009 Posted April 28, 2009 Here's something like I was telling you about Destiny Flyer EMI Suppressor And here's some reading on how, why and what to do for you... Info
Guest basscheffers Posted April 28, 2009 Posted April 28, 2009 Have not heard much good about the HME-95 when I was researching. I ended up getting the HME-100 (on a trip to Europe, for a whole lot less dough than here at the time) and they are great. Much lighter than "standard" DC 13.4 and sound much better. Apparently, I sound great on them too. Only downside is that the gel seals on DC are better, you really need very thin sunglass arms not to break the seal on the Sennheisers.
