Guest Andrew Posted April 6, 2009 Posted April 6, 2009 Ladies & Gents, Can you offer any advice on Skyfox wheel rims? Mine are a little worse for wear and I have a consistent slow leak from damage around the bead area. I would prefer to replace them with the same and maintain the factory built status, however I will consider changing if the design of fixing to the hub is improved etc. I have recently fitted new tyres with little improvement. Many Thanks, Andrew…
