hugues Posted February 25, 2009 Posted February 25, 2009 Hi everybody, I own a P96 golf 100 since 2 years and I always have a problem with my cabin heating system. This equipment doesn’t work correctly except … during the summer … I check all the tubes, from the air intake to the cabin. All is clean, without any obstruction. My conclusion is that there is no pressure difference between the front of the plan and the cabin inside during the fly. Than the air flow can’t circulate. I’m looking for a fan to resolve this issue. Does anybody know a system for that ? Thanks
slartibartfast Posted February 25, 2009 Posted February 25, 2009 Welcome to our first (I think) Luxembourger. I decided to build a rear-facing scoop in the base of my cockpit area. The airflow past this creates negative pressure in the cockpit and gives fantastic ventilation when the naca vents are open or cabin heat is on. You could make one that is cable operated so it could be closed. I don't find it necessary though.
