rebuild barrel
hi all,
the group sure has grown since I first joined, great to see !
In the middle of my tst-e rebuild, thinking about a barrel fuel tank. {Are there different capcities}instead of oblong one [any advice], anyone know whereabouts of one,
also need radio, intercom headsets [any advice on brand or type ]
and a few instruments eg..vsi ,dual egt and cht
anyone know of a good cable maker 2.5 and 3mm 7/19 s/s.
Hey Thrasher,,, are you ringo ? I stillhaven't been able to source my alloy u/carriage beam , looks like I'm going with a reconditioned old one
thanks guys Percy
Percy: Re the TST axle/carry thru bar parts etc
For your info, both 'Drano' (see his posts elsewhere on thiswebsite) and Randall of Crowley Aviation, Junee, NSW, ([email protected]) advised recently that they held stocks of both the 4130CrMo insert and 6061 T-6 alloy carry-thru rect tube material in correct lengths. But be warned..it ain't cheap!! Supply of new wire traces shouldn't cause you a problem but if so, get in touch as I havegood used ones surplus to my needs.
Cheers Bob
Thanks Bob for your help much appreciated,
Percy
Hi Percy
No he's not Ringo he's Steve.
We had to recondition ours too it seems fine now.
We use a Icom A22 with a HM Intercom sorced from Mendelssohn's (see back page of latest RA-Aus Mag)with some Peltor Headsets which all works well.
Thanks Steve, for info, I will investigate that set up.
The Icom A22 doesn't seem to be available must be superceded by the A 24 >Do you know ?
Sorry about the Ringo mix up
Percy
