mr badger Posted January 4, 2009 Posted January 4, 2009 HI FOLKS JUST WONDERING IF ANYONE HAS CHANGED STREAK SHADOW PULTRUSION LEGS ON A STREAK SHADOW? MANAGED TO GET THE OLD ONES OUT DIRTY LONG JOB, MY QUESTION IS COULD YOU REPLACE THE G R P LEGS WITH MOLY TUBE OF THE SAME SIZE ANY THOUGHTS CHEERS GARY
Guest slenne Posted January 6, 2009 Posted January 6, 2009 streak shadow legs Hi ibuilt a streak shadow in 95 . I reckon the legs worked well , you neede to be carefull fitting them to get the wheel alignment right . they are forgiving . the only improvement i could suggest would be to stream line them.
