Guest Johnmac Posted December 16, 2008 Posted December 16, 2008 The battery in my Skyfox Gazelle is slowly dying, the supplier recommended for a new battery "Helitech" in Brisbane is out of supplies until mid Jan. Does anyone know an alternative supplier, the part number is 397.19 12V 30 AMP dry fit. I have searched the maintenance manual but cannot find a brand name?
rick-p Posted February 5, 2009 Posted February 5, 2009 If it helps anyone I just use a DELCOR calcium battery with the appropriate specifications successfully for years. Rick-p
Guest yarraroo2 Posted July 18, 2009 Posted July 18, 2009 skyfox battery replacement I have a Skyfox CA22. My L2 Said to buy a 'jump start battery pack'. Get the 900cca one which is 17 amp hour. It is a sealed lead acid battery and is the cheapest way to buy the battery. You even get a few bits and pieces for free. I have been running one for about 8 years. It works really well. It is lighter than the helicopter battery originally installed in my aircraft. Either check your weight and balance or add a little weight to compensate. Or even get a larger sealed lead acid battery which is not necessary. I bought one recently for another application for $75. Beats the $300 for the certified battery. Cheers Yarraroo2
