Spriteah Posted December 9, 2008 Posted December 9, 2008 Hello peoples, Im having problems with a SL40 that sometimes (not always) has a high pitched squeal on transmint. It does not seem to be feedback. I have david clark headsets. It wont occur if both mikes are out. Any idea's. Jim.
Guest Maj Millard Posted December 9, 2008 Posted December 9, 2008 Have you changed headsets or radio/intercom units recently ?. Sounds like it could be microphone related. Either an Electric or dynamic mic is suitable for you'r radios, but not both.
newairly Posted December 12, 2008 Posted December 12, 2008 It could be RF getting into the mic/intercom. This could happen if the antenna or cable is faulty causing RF to be radiated away from the antenna. Maybe something has changed. I have a similar problem with an Icom A20. I can not use a headset with the built in whip, but it is OK with an antenna mounted remotely. Good luck. These things can be very frustrating. Phil
Guest Cloudsuck Posted December 12, 2008 Posted December 12, 2008 I had the same thing with my A200 when I installed it in my Tecnam. I found the mic gain pot on the outside of the casing and peeled back the little silver sticky sticker and screwed back the mic gain a bit. Problem solved.
