Deskpilot Posted November 3, 2008 Posted November 3, 2008 Subject: JUST A BIT OF CULTURE It was necessary to keep a good supply of canon balls near the cannon on war ships. But how to prevent them from rolling about the deck was the problem. The best storage method devised was to stack them as a square based pyramid, with one ball on top, resting on four, resting on nine, which rested on sixteen. Thus, a supply of 30 cannon balls could be stacked in a small area right next to the cannon. There was only one problem -- how to prevent the bottom layer from sliding/rolling from under the others. The solution was a metal plate with 16 round indentations, called a Monkey. But if this plate was made of iron, the iron balls would quickly rust to it. The solution to the rusting problem was to make Brass Monkeys. Few landlubbers realize that brass contracts much more and much faster than iron when chilled. Consequently, when the temperature dropped too far, the brass indentations would shrink so much that the iron cannon balls would come right off the monkey. Thus, it was quite literally, cold enough to freeze the balls off a brass monkey. And all this time, you thought that was a vulgar expression, didn't you? You must send this fabulous bit of historical knowledge to at least ten unsuspecting friends. If you don't, your hard drive is going to fall off and kill your mouse. ----------------------------------------------x
