farri Posted August 2, 2008 Posted August 2, 2008 Hi everyone, I need some information on the 3 blade 60 inch diameter,Ivo propeller. I`ve been told that this prop is not realy suitable for the Rotax 582 with a 2.64:1 reduction gearbox as the prop develops cracks. Is there anyone using the prop on the 582 and if so could you please tell me of your experience with it. Cheers, Frank.
Guest Carl Booth Posted August 2, 2008 Posted August 2, 2008 ivo prop Hi . I used a black 3 blade ivo prop some years ago, fitted to a 447 however. The prop is quite heavy (for carbon props) in my opinion, and I subsequently replaced it for a beautiful light French Arplast prop. I did not observe cracking in the Ivo prop. Carl
farri Posted August 2, 2008 Author Posted August 2, 2008 Hi Carl, Thank you,what I need to know is weather the prop is ok with the 582. Cheers, Frank.
Skyhog Posted August 14, 2008 Posted August 14, 2008 Hi,I have been running a ground adjustabe Ivoprop for about 150 hours on a 582.No cracks,no complaints,no worries.
farri Posted August 18, 2008 Author Posted August 18, 2008 Hi Skyhog, Thank you for that. Cheers, Frank.
thommo Posted August 18, 2008 Posted August 18, 2008 I am also running a ivo prop on a 582 on a thruster, and also ran one on a 582 in a se5a biplane with no problems.
