skippydiesel Posted July 8, 2025 Posted July 8, 2025  Does reflexing the flaps, by a few degrees (1-6) have a;  significant improvement to cruise speed ? detrimental effect on stall speed WITH flap ?  😈
Thruster88 Posted July 8, 2025 Posted July 8, 2025 Significant improvement in speed, no. If there was every manufacturer would be doing it. Maybe it is some times used to correct a design that is not quite right.  Change in stall speed with full flap? I presume you mean if there is 5° reflex your max flap is reduced from say 40° to 35°. The last bit of flap travel does little for stall speed reduction, it just adds more drag so negligible change in stall speed. 1
Freizeitpilot Posted July 8, 2025 Posted July 8, 2025 A good thread on reflexed flaps from way back in 2014.  https://www.recreationalflying.com/forums/topic/23881-reflex-flaps-and-ailerons/ 1
skippydiesel Posted July 8, 2025 Author Posted July 8, 2025 (edited) 2 hours ago, Freizeitpilot said: A good thread on reflexed flaps from way back in 2014.  https://www.recreationalflying.com/forums/topic/23881-reflex-flaps-and-ailerons/ It was pretty inconclusive back then, with about equal for & against (assuming against includes those who felt no significant benefit/effect).  A few commentators seemed to think that the European small aircraft manufactures supported/included this feature in their aircraft (I was one).  I would ask - If this feature works for the EU why not AU & US (etc)? That the 11 years since that debate may have found some more evidence for & against? Could the main wing aerofoil have an influence on reflex being a significant benefit ? 😈 Edited July 8, 2025 by skippydiesel
