w3stie Posted May 7, 2008 Posted May 7, 2008 Hi Does anyone know who could supply the tap or hardware/plumbing to switch between dual fuel tanks? This is for use in a car so would be switching fuel input and fuel return (EFI setup). Thanks in anticipation.
Yenn Posted May 7, 2008 Posted May 7, 2008 Have a look at Wicks or Aviation Spruce to see what you need and if you see what you want, either buy it from them in USA or try Aviaquip. [email protected]. They seem to carry a pretty good range of gear. Be aware that aviation flared joints are 37 deg, not the same as auto flares.
Seal Posted May 7, 2008 Posted May 7, 2008 The Rolls Royce solution is here http://www.andair.co.uk/system/index.html but any dual tank switching setup for a diesel will work as these have flow and return lines. Look in the 4WD accessory suppliers. Cheers, Selwyn
