Qualcuno conosce il riferimento delle bronzine del Jabiru 2200a ? Quelle vendute da Jabiru sono sicuramente di origine automotive, forse Isuzu? Grazie
Fabio
Hi Fabio - This forum uses the English language as the standard format. If you wish to receive answers to your question about the Jabiru engine, you need to write your posts in English.
With regards to Jabiru "bushings", we need to know precisely which bushings you are referring to, as "bushings" is a common term that includes numerous but different parts.
  • Helpful 1
A quali boccole ti riferisci Fabio? Forse le boccole di montaggio del motore in gomma?
Which bushings are you referring to Fabio? The rubber engine mounting bushings perhaps?
Google translate to the rescue - piece-o-p...............
