I have received my Skyecho2 and have the required hex code. I believe I have configured it correctly through the wifi connection and browser. Unfortunately AvPlan is refusing to connect. Also the Skyecho2 is not transmitting- the middle green light flashes slowly. Can anyone tell from my description what I might have missed? Laurie
The middle light will flash when on the ground indicating it is in ground mode. The minimum airspeed of your aircraft is one of the parameters in the setup. Hope this helps.
2 hours ago, mkennard said:
So you joined the wifi of the skyecho on the iPad?
Yes and completed the set up page. When I check‘external devices’ in AvPlan it comes up ‘refused’. Laurie
Hi KA,
Sounds weird.
I have no problem with my Skyecho and Avplan on my iPad Mini. Suggest you call the AVPlan Support people - I have always found them very helpful.
Cheers,
Neil
Carl from Avplan replied and cleared things up on New Years Day.  Excellent service.  Laurie
Yes they have been very receptive to all my queries over the years as well
