lyle janke Posted November 5, 2022 Posted November 5, 2022 hi all i know this is an old topic but i want to see who has recently done any work on U/C wheel alignment ?? i have asked jabiru the supported method pack with washers -test /check & flock final result nowhere in the responses did i read how you all made bolts holding axle fit ( 1 response "i just bent the bolts " jabiru suggest -"elongate holes in leg until the bolts slide through the assy " ) i wondered if instead of washer packing & flocking i could get a 3D-printed shim (what material ?) a machined metal shim ? or use JB -weld liquid steel to flock the washer method instead of resin who has any thoughts or used any of suggestions to solve camber problem ?? thanks for your thoughts
