Guest Macnoz Posted April 16, 2008 Posted April 16, 2008 Just wondering your thoughts and practice on parking a two blade wooden prop? The scientific answer I know is horizontal so as to avoid the likelihood of the water / fluids in the timber flowing to the bottom and causing an imbalance. I wonder however if this is really an issue in a regularly flying or at least engine turned craft? I feel that there is a greater chance of hangar rash or other impact, trolleys, pedestrians etc to a prop when parked horizontal both when parked and maneuvering the craft around
Guest Ken deVos Posted April 16, 2008 Posted April 16, 2008 ....The scientific answer I know is horizontal so as to avoid the likelihood of the water / fluids in the timber flowing to the bottom and causing an imbalance....[/quote]My understanding is that a horizontal prop position reduces the moisture from rain, mist, condensation etc. on the prop surface, that would otherwise run down into the hub and eventually cause swelling of the wood.
eastmeg2 Posted April 16, 2008 Posted April 16, 2008 I still remember the answer given when I asked the same question many years ago when dabbling with Gliders at Bathurst Soaring Club. (Refering to the tug at the time). I was told that positioning the prop horizontally eliminates the chance of the prop being swung over/driven by the wind. Sounded strange at the time, but if you think about it the ground provides a barrier to vertical air movement. If the prop is placed vertically the wind could achieve optimal angle of incidence to the prop when it blows from a certain direction - although if it blew hard enough to turn the prop over you'd think that would be the last of your worries. Cheers. Glen
old man emu Posted April 16, 2008 Posted April 16, 2008 I was originally told to park the prop vertically to prevent birds perching on it, then jumping across into the engine bay via air intake holes in the cowl. Then I started working in a maintenance hangar and was told to park the prop horizontally to prevent water entering (seemed funny when most of the aircraft had metal props). I don't know how many times I've nearly walked into the tip of a prop while going across the front of an aircraft in the hangar. I have heard that in the USA, the position of the prop (horizontal or vertical, can't remember which)) is a signal to refuellers that you want your aircraft refuelled. Hows do you answwer this question for the bloke with the three or four-bladed prop? Old Man Emu
Matt Posted April 16, 2008 Posted April 16, 2008 Hows do you answwer this question for the bloke with the three or four-bladed prop? 3 Blade prop = 1 blade vertically down - effectively a 'Y' alignment 4 Blade prop = blades in an 'X' alignment are the common approaches
Ultralights Posted April 16, 2008 Posted April 16, 2008 where the prop stops on shutdown dictates the prop position.
Guest Redair Posted April 18, 2008 Posted April 18, 2008 where the prop stops on shutdown dictates the prop position. Often wondered about this one too, as I have seen quite a few people get out of their aircraft and then turn the stopped prop from its position by hand to the horizontal position, and even a couple who turned it vertical. Redair.
Guest Macnoz Posted May 20, 2008 Posted May 20, 2008 Just talking to my "old" CFI in Ireland about this and he reminded me of why I am a climatic refugee. Leave it horizontal so that condensation forming on the spinner doesnt flow down one blade and freeze causing prop problems
Guest High Plains Drifter Posted May 20, 2008 Posted May 20, 2008 If I need to move the prop, I let the engine cool down a bit first. .
Seal Posted May 21, 2008 Posted May 21, 2008 The scientific answer I know is horizontal so as to avoid the likelihood of the water / fluids in the timber flowing to the bottom and causing an imbalance.I wonder however if this is really an issue in a regularly flying or at least engine turned craft? I feel that there is a greater chance of hangar rash or other impact, trolleys, pedestrians etc to a prop when parked horizontal both when parked and maneuvering the craft around I agree that is the common answer but it is not a very scientific one. Given the structure of wood, water does not flow through it in any normal sense, it moves via capillary action and vapour transfer neither of which are much affected by gravity at the moisture content typically encountered in a propeller. The idea that all the water in the prop is going to run down through it to one end is just a bit silly. A better question might be to think about the possible effects on water entry to the propeller. The idea being that we would want to minimise this to keep the internal moisture content as stable as possible. If the aeroplane is in a hangar, it is not getting wet so it really does not matter, from a moisture point of view, how it is aligned. You may as well leave it where it stops. If it is outside and going to get rain or dew on it, which way should it go? If you put it horizontal then the leading edges are going to be more exposed to water either from rain directly on the upper edge or from drops of condensation collecting on the lower edge. And where is the protective finish likely to be damaged? If you have a metal protective strip then you definitely don´t want a leading edge down as water will get in under the protective metal at any break in the seal between metal and wood, the area will remain damp and the wood will be damaged. Horizontal is not good. If you put it vertical then moisture does not stand on the leading edges and any that gets under protective strips has a chance to drain. Proper metal protective edges have drain holes to facilitate this. However, as a previous post mentioned, water can run down to the hub and possibly get under the mounting flanges, become trapped and cause swelling and other problems. Vertical is not good. All is not lost however. If you put it on a diagonal then you get the best of both worlds, the edges drain and contours around the blade root will deflect most moisture running down the blade around the hub area so the mounting flanges stay dry. There are plenty of pictures of rows of tigers and the like, all with wooden props parked at an angle, taken in the days when they knew a thing or two about operating wooden props. As others have mentioned, you also get the other benefits. The propeller is less exposed to hangar rash, being walked into, being used as a perch to encourage sparrows to nest in the engine or being used as a towbar to drag the attached aeroplane around. This last is an all too common practice which has far more potential to damage a wooden propeller than has any effect of how it is parked. Finally, a few words on respect for propellers from someone who spent several years operating with Gypsy Majors including hand starting the things. The big lesson learned from that was to never trust a propeller, there was an even chance that it had homicidal tendencies. It makes me cringe when Biggles arrives shuts down the engine, hops out, grabs hold of the prop, pulls it through a couple of compressions to get it to whatever position he has been taught then drags it off to his parking spot with a hand clamped around, usually one blade. It happens all over the place every weekend. For any engine with impulse magnetos this is just Russian roulette with a blunt axe. Even with electronic ignition engines there is a real risk. They may be hard to start but it is only a matter of time before the thing gets a bit of glowing carbon in it, there is no mixture cutoff so there is plenty of fuel there and it pops over a few compressions. That´s all it takes to cause smashed fingers and serious cuts, not to mention incidental prop damage. I´ve seen it happen, it has happened to me and the only reason I still have all my fingers is because I assumed it was going to and used proper technique to get my hand out of the way before the next blade came around. Please, don´t treat your propeller like a handle, treat it like the dangerous tool that it is.
