Markdun Posted May 15, 2021 Posted May 15, 2021 Contemplating how I could install a remote transponder in my Corby (definitely no room on the panel for a transponder) with it being controlled by my MGL Xtreme EFIS. Seems there are plenty of cheap Garmin XTR33 around. You would think manufacturers would publish their RS232 protocols but alas, no. The MGL setup is for a Sanden remote transponder, so it has the functionality. Has anyone either worked out the protocols or built a multiplexer/converter?
Tasmag Posted May 16, 2021 Posted May 16, 2021 Might be worth asking on this forum. Rainier, the founder and CEO of MGL will most likely give you an answer within a day or two. Mike http://www.mglavionics.co.za/phpBB3/index.php
