waraton Posted May 16, 2020 Posted May 16, 2020 Id like to run a handheld icom A15 VHF and GME 3100 UHF in an single seat open frame machine. Ideally monitor both radios while switching to transmit on one or the other. Are there any "plug and play" devices which work well? If you run a system which does this how did you set it up?
KRviator Posted May 16, 2020 Posted May 16, 2020 Some Jabiru (Jabirus?) have a UHF radio fitted as a factory option. You might touch base with the factory up there to see who is their supplier, or if they build their own harnesses they migh tsell you one. Retails about a $1,000 option on their kits.
propfarmer Posted May 16, 2020 Posted May 16, 2020 www.backpackairsports.com.au can custom make whatever you want in that type of thing. Give Adrian a call, you may need to send him your headset.
onetrack Posted May 17, 2020 Posted May 17, 2020 The correct website link is - http://www.backpackairsports.com/
