WestCoast Posted March 12, 2008 Posted March 12, 2008 Anyone operating a Neuform In-Flight Variable pitch propeller should aquaint themselves with Service Bulletin NEUFORM TM-08-01. (issued 22/2/2008) Apart from the exempted serial numbers listed in the SB, all affected propellers will need to be retrofitted with shear pins and fitted with bolts with roll formed threads. Flight Design in their Tech Advice 15 (Rev 1) has indicated that compliance is 'prior to your next flight', so the matter is urgent. Should you have a problem locating the SB, contact me and I will forward it to you. Dave
