Guest Guest Posted July 31, 2006 Posted July 31, 2006 Hi team, Has anyone else had a problem with the sprag clutch in the 912uls engine. The more I investigate it would appear that there is an issue with this configuration especially if the smaller starter motor is installed. Most of the problems are documented on the matronics web site forum in the europa digest. http://www.matronics.com/listbrowse/europa-list/index.html It is required to change the sprag clutch circlip at 1200 hours for a slightly larger one, but there seems to be a few, like mine, that break earlier, and in my case go through the engine. Before this happened I don't think I had even heard of a sprag clutch. Anyway, any feedback will be great! regards Gtblu Wait a minute... is that John... no no surely not! gtblu
Guest bateo Posted December 14, 2006 Posted December 14, 2006 Gtblu, What was the outcome of this situation, What do you mean going through the engine??? I have had the same trouble...
Guest bateo Posted December 16, 2006 Posted December 16, 2006 G'day Gtblu, I have had the same troubles with my Rotax 912, It seems the sprag clutch is not engaging.. I would really like to know any feedback of sorting/investigating your problem..Mine needs changing, is it hard to replace yourself?Could you reply asap.. Regards
