Guest Tom Posted May 26, 2006 Posted May 26, 2006 What's the prerequisite... Or how you do it while flying... Is it a Flightwatch to contact re base being active or not?
PaulN Posted May 26, 2006 Posted May 26, 2006 Hi Tom, From my experience with Williamtown (also a Mil CTR) you should call ACD (Amberly Clearance Delivery) on 134.6 at the req'd contact point (usually 10nm prior CTR). If active you'll get the normal response. If inactive you would expect no response so then call TWR (Amberly Tower) on 118.3 which is also the MBZ freq. Last time I passed Willy this was the sequence, however I got no response from TWR but other a/c in the area confirmed that normal MBZ protocol was in place. To get clearance when active you should have a transponder and should have PPL. Hope this helps, PaulN
PaulN Posted May 26, 2006 Posted May 26, 2006 Me again Tom, I just re-read your post. Yes, Flightwatch should help with info re active or inactive. I think Flightwatch freq there is 128.15. PaulN
