CASA Airworthiness Directives published between 19/10/2018 and 01/11/2018
The Civil Aviation Safety Authority has published the following Airworthiness Directives between 19/10/2018 and 29/10/2018.
These, and other Airworthiness Directives can be viewed at:
Rotorcraft
Airbus Helicopters Deutschland (Eurocopter) MBB-BK 117 Series Helicopters
2018-0225-E - Equipment & Furnishings - Hook Mount Assembly - Inspection
2018-0230 - Integrated Modular Avionics - Aircraft Management Computer Software - Modification
Bell Helicopter Textron UH-1 (All Variants) Series Helicopters
PAD/UH-1/20 - Tail Boom and Fin - Fretting and Cracking
Kawasaki BK 117 Series Helicopters
TCD-9188-2018 - Goodrich Rescue Hoist P/N 44301-10-7 - Hook Mount Assembly Lock Spring System
Robinson Helicopter Company R22 Series Helicopters
DCA/R22/50 - Helipod III Spray System STC 7/21E/9 - Removal from Service
DCA/R22/51 - Helipod NZ Limited STCs - Report of Installation
Robinson Helicopter Company R44 Series Helicopters
DCA/R44/36 - Helipod NZ Limited STCs - Report of Installation
Above 5700 kgs
Airbus A319, A320 and A321 Series Aeroplanes
2018-0218 (Correction) - Wings - Center and Outer Wing Box at Level of Rib 1 Junction - Inspection
2018-0231 - Time Limits / Maintenance Checks - Airworthiness Limitations Section Part 5 - Fuel Airworthiness Limitations - Amendment
2018-0233 - Fuselage - Cargo Compartment Fitting Brackets, Tack and Rivet Holes - Inspection / Repair
Airbus A330 Series Aeroplanes
2018-0226 - Stabilizers - Horizontal Stabilizer Centre Box Top Skin - Inspection / Repair
2018-0227 - Exhaust - Thrust Reverser Latch Beam Gussets - Inspection / Modification
2018-0228 - Power Plant - Engine Air Inlet Cowl Inner Barrel Lower Panels - Inspection / Replacement
Boeing 787 Series Aeroplanes
2018-22-04 - Inboard and Outboard Trailing Edge Flap Rotary Actuators - Inspection / Replacement
Bombardier DHC-8 Series Aeroplanes
CF-2018-21R1 - Wings - Cracked Spoiler Actuator Bracket
Turbine Engines
General Electric Turbine Engines - GE90 Series
2018-20-22 - Combustion Case Replacement
2018-20-23 - HPC Rotor Stage 2-5 Spools
