nig71 Posted August 22, 2018 Posted August 22, 2018 Is the best way to get UHF in an aircraft to install a dedicated unit in the dash? Is there a way to use a handheld walkytalky through headsets. All I want it line of site communications. Is there a harness available? Seperate key for activation? Or do you use the key on the walkytalky ? Â
Bluboyz Posted August 22, 2018 Posted August 22, 2018 G'day nig71, Can you indicate the type, make or model for the:- aircraft, aircraft VHF radio(s), (intercom if fitted), and your intended UHF h/h or panel mount. A panel mounted rotary switch is a common method used in recreation aircraft, Microair and other brands have info on their sites. eg Microair 760P and UHF adaptor ~ http://www.microair.com.au/admin/uploads/documents/MAW1002M760PUHFAdaptor01R2.pdf Â
nig71 Posted August 22, 2018 Author Posted August 22, 2018 G'day nig71,Can you indicate the type, make or model for the:- aircraft, aircraft VHF radio(s), (intercom if fitted), and your intended UHF h/h or panel mount. A panel mounted rotary switch is a common method used in recreation aircraft, Microair and other brands have info on their sites. eg Microair 760P and UHF adaptor ~ http://www.microair.com.au/admin/uploads/documents/MAW1002M760PUHFAdaptor01R2.pdf Haven’t got one yet but looking at options on a vixxen . Uhf option costs $4250; not bad for $600 unit. I’ve seen one in a photo in a Kelpie and it’s just a GME unit I might use in my ute. It is of course missing the mic and is wired into the intercom. Â
Thruster88 Posted August 22, 2018 Posted August 22, 2018 A handheld with headset adapter would be the lightest and cheapest. I have an icom a15 VHF as backup works well with the adapter i just use the ptt on the unit. A high power handheld in an aircraft will transmit over 100km  1
rankamateur Posted August 23, 2018 Posted August 23, 2018 Xcom add a harness to a standard dash mount GME uhf set to interface with their airband set, I installed them myself, nothing challenging, just regular tools and farmer skillset.  1
Old Koreelah Posted August 23, 2018 Posted August 23, 2018 A handheld with headset adapter would be the lightest and cheapest. I have an icom a15 VHF as backup works well with the adapter i just use the ptt on the unit. A high power handheld in an aircraft will transmit over 100km ...and they go even further if connected to a good external antenna.  1
rankamateur Posted August 24, 2018 Posted August 24, 2018 ...and they go even further if connected to a good external antenna. Commant 121 in the kit I got, I installed it on top, but put the unity gain UHF antenna under the fuselage, it still has plenty of ground clearance. Â
Hargraves Posted August 26, 2018 Posted August 26, 2018 HAT hight above terain for uhf transmitions formula is twice the height in feet squared expressed in miles ie 5000' x 2 = 10,000' squared = 100 miles Â
nig71 Posted March 7, 2019 Author Posted March 7, 2019 Xcom add a harness to a standard dash mount GME uhf set to interface with their airband set, I installed them myself, nothing challenging, just regular tools and farmer skillset. Got any links to this harness? Â
skippydiesel Posted March 7, 2019 Posted March 7, 2019 My Rotax 912 motivated aircraft is quiet enough to be able to use a hand held UHF, with one cup of headset pushed away from ear, - works for me and way cheaper than integrating with VHF aircraft comms and means I can take the handheld and use it for other ground based applications. Go with the KISS principal !  1
rankamateur Posted April 10, 2019 Posted April 10, 2019 Got any links to this harness? Just had a look around the internet, looks like Xcom has gone the way of the DODO which is a shame if true. Â
