newairly Posted January 6, 2008 Posted January 6, 2008 Just noticed this in Sydney Morning Herald. http://www.smh.com.au/news/national/flying-machine-takes-high-road-to-work/2008/01/05/1198950128938.html It is a combination of a 3 wheel car and a gyrocopter. The specs look interesting. However the weight of 550Kg (empty I assume) may preclude registration here as an ultralight. Phil Technical data Performance on land Air performance DimensionsTop speed: >200 km/h Max airspeed: 195 km/h Rotary nginePower output: 213 hp 0 - 100 km/h: < 5 sec Min airspeed: 30 km/h Length: 4 m Max tilting angle: 30° Take off distance: 50 m Width: 1.2 m Estimated fuel economy: (100 km/h) 30km/litre Min landing distance: 5 m Height: 1.6 m Range: 600 km Range: 550 km Weight: 550 kg Fuel: 95/98 unleaded
Allan Posted January 6, 2008 Posted January 6, 2008 Some machine huh? Quote: "Top speed: >200 km/h Max airspeed: 195 km/h 213 hp Estimated fuel economy: (100 km/h) 30km/litre Weight: 550 kg" Note at 100km/h (a bit below 50 knots) it's burning only 3.5 litres/hr! (ie. 100km/h / 30km/l). Not bad for what is basically either an helo- or a gyro-copter at 550kgs! But also note it's just an "estimated fuel economy", but is that land cruising or flying? Believe it when I see it!
Guest David C Posted January 6, 2008 Posted January 6, 2008 Believe it when I see it! Yeah me too .... It's not 1st April already is it ??
Yenn Posted January 8, 2008 Posted January 8, 2008 If it sounds too good to be true it probably is. Just working out the fuel, the ruke of thumb is 0.5lbs / hp /hour which equates to about 69 litres per hour at full bore, even halving it becomes way over the quoted figure. 0 to 100 kph < 5 sec "Wow"
Guest Fred Bear Posted January 8, 2008 Posted January 8, 2008 Thread is already here: http://www.recreationalflying.com/forum/showthread.php?t=6678
Guest ozzie Posted January 8, 2008 Posted January 8, 2008 I'd buy one of these just to see the faces on the guys down at the RTA office when i rocked up to register it for the road. With all the designs both actually funtional or not of the "flying car" concept i think my favorite would be the one from the James Bond film 'Man with Golden Gun' Or seeing how the sea level will rise this century hows bowt the 'Flying Sub" from 'Voyage to the Bottom of the Sea'. They still have a ways to go, i belive. ozzie
