CL Flyer Posted November 16, 2018 Posted November 16, 2018 Hi Jaba-who and others, There is nothing tricky needed to insulate the engine from the firewall. The mount frame is attached to the firewall and so becomes part of it electrically. The rubber mounts between the mount frame and the engine do the insulating there. Care has to be taken to track down every earth, so it does not go to the firewall (or mount frame). It may be necessary to create a separate earth bus using a brass or copper bar. Every installation is different so that would be up to the modifier. The cost is low, but there is some time required to change the earth system so it stays away from the firewall. Two to three weeks would probably do it. CL flyer
