You can't get any cheaper than this weeks Recreational Flying Clear Prop Special!
Dictionary of Aeronautical Terms - Aviation is an industry full of terms, acronyms and technical language. This book helps users understand all the words, abbreviations, phrases, and disciplines of aviation.
Only a couple at this price so get yours today at:
Also, did you know that when you purchase your pilot and aircraft needs from the Recreational Flying Clear Prop bargain priced store you are rewarded for your purchase. For example:
- if you spend between $25 and $75 in one purchase you can get the Helicopter TIF book for only $1
- if you spend $75 or over in one purchase you can get both books:
1. Flight at Lower Levels - Safety in the Circuit
2. Flight at Lower Levels - Safety Through Awareness
FOR ONLY $10 (that's only $5 each)
So when shopping at Clear Prop don't forget to check out the extra cart specials when viewing your cart before checkout. Just another way we help you to save on all your aviation needs at Clear Prop
