Does anyone know where I can buy a rib pattern for my Wizard II. I've had it for 15 years & it flies squirrely.
Also, didn't Wizardb issue an AD for the nose attachment bracket to be replaced years ago?
Need that too. Thanks for any help!
Bill Callahan
If it is the same as the streak 2B the suspect bracket was a thin stainless one and updated with a thicker aluminium one? You will find the full AD on airbornes sight.
Thank you Tassy!
