Brett Posted February 6, 2009 Posted February 6, 2009 Well just finished building my aerovee at work this week and brought it back home ..will plonk it onto the mount this weekend just to see how it fits.. looks like I will have to modify the cowl a fair bit as the aerovee is a few inch wider than the jab donk .. Hows the flying been in the ones that are airborne guys ??????
Guest Curandero Posted February 6, 2009 Posted February 6, 2009 Hi Brett, I have 100+ hours on my aeropup and all is going well. I will be interested to know how the streamline from an even wider front end will look as it slims past the fire wall. curandero
Brett Posted February 6, 2009 Posted February 6, 2009 I'll have to paint the cowl in a slimming colour
Mark Posted February 8, 2009 Posted February 8, 2009 Still building ..... Hi Brett, My Aerovee is sitting on the front now and has been there for a while now. I have built the cowls and made cut outs for the rocker covers to fit through. Maybe one day I will shape the fiberglass around them. I have fitted a Sweetapple prop 56"D x 38"P. Fitting the leading edges onto the wings this weekend and had the seats covered this week. It is all coming together slowly. Mark
Brett Posted February 8, 2009 Posted February 8, 2009 Coming along a little quicker than mine I think ,,, I wish I didn't have a house to build at the same time (we finished the tiling last weekend) ,,at the moment I do one weekend to plane and one weekend to house ,,the house is very close to being finished (hoping soon) then will be all go on the plane :) Let me know how you go with that prop when you fire the big girl up ,,, I'm still quite away from that but I think I will start doing all the wiring for the engine,, gauges and so on ,,,spose it doesn't matter what order things are done in as long as it's all done in the end...
Mark Posted February 10, 2009 Posted February 10, 2009 Yeah, I have my panel in and about to do the wiring. I bought the AeroVee trim system and their spinner (which is solid ally and quite heavy). There was a bit to do to get the brakes operational. I am going to try motor bike hand leavers to give independent braking, mounted on the floor under my knees. Starting to think about fabric. Mark
Brett Posted March 11, 2009 Posted March 11, 2009 Well I have just finished painting the front of the frame tonight as on the starboard side I was missing the strips to mount the side panel. I had to weld on some flat bar so as I could rivet the panel on without having to drill through the tubing structure.. was a real shame to ruin that beautifully powder coated finish but didn't have much choice I thought. Had a welder mate tig it on and it came out sweet,,,rubbed it back, primed it up and on with some paint that was recommended by the local powder coater up here. Had to completely strip the frame to transport it there but really I hadn't gotton that far on the fuse so was not much of a chore. Mark I was looking at a photo I got from JC,, I guess from when he made the mount for the aerovee and was wondering if he temp fitted it onto your frame ,,,looks from the picture the same strip was missing ,,,did you have the same drama? The brake idea sounds good and I have been really wondering about what to do there as well,,,, Think I will wait right till the end b4 I buy a prop ,,,from what I gather the aerovee turns a left hand prop, havn't seen anything on the site about it pretty sure it is.
Guest swede Posted March 14, 2009 Posted March 14, 2009 Hi There, I have mounted my "m-cycle" brake levers in the middle of the instrument panel on the 16 mm cross over tubing running underneath by turning a drilling a 16 mm hole and then turn and split a 25 mm solid piece of aluminium, the end of the levers are facing each other - I am 6ft2 and have a long reach - no problems reaching the levers... cheers SWEDE
Brett Posted March 14, 2009 Posted March 14, 2009 any chance of a posting a picture?? soz but I'm having a little trouble picturing that in my head ..
Guest swede Posted March 14, 2009 Posted March 14, 2009 Hi Brett - see if this works... Pictures by vk2fln - Photobucket
Brett Posted March 29, 2009 Posted March 29, 2009 G'day guys,,,just got back from a 1000km round road trip to have a look at a (just about to under go final inspection) aeropup with a 6 cyl jab clamped on the front ;) .. I'm guessing with those sort of horses up front it will prob leap of the runway ... will be good to hear how it all goes once it's flying. cheers for that photo swede :thumb_up: ,,, the brake setup on this plane was similar to yours but face downwards ,,, however still deciding what to do with mine.
Brett Posted April 27, 2009 Posted April 27, 2009 hey Guy's,,,just a query if anyone can remember or have a look,,, on the last outer wing tip ribs where the fabric brace struts are riveted through the rib itself ,,,,the alloy angle that is used ,,,,, what size is the aluminum angle used? Is it the same as the angle used to mount the cowling at the top which is 1" x 1.5" ??? or can a smaller gauge angle be used,,,,bit hard to work out from the plans ,,or I just cant see where it is listed anyway ??? refer the drawing WM2 if I haven't explained very well. The 4 x tubes 1+2 and 8+9 rivet onto the angle in the picture.. thanks
Guest swede Posted April 27, 2009 Posted April 27, 2009 3 57-10-15 Stiffener Angle 0.040”Th. M 2 Ea Al Alloy I think this is what you mean: Item 3 Regards SWEDE
Brett Posted April 27, 2009 Posted April 27, 2009 Thanks for that ,,,,looks like I'll be going shopping tomorrow
Brett Posted May 20, 2009 Posted May 20, 2009 Bruce ready to fly the ?Aeropup? he built - Local heroes - inMyCommunity - Perth, Western Australia
raymondhallatt Posted May 31, 2009 Posted May 31, 2009 Hi Bruce Do you live in WA and was that bruce Baileys Aeropup you went to look at . I am curious because I know bruce as he is a fellow member of the SABC at serpentine airfield. Cheers Ray
Guest Curandero Posted June 1, 2009 Posted June 1, 2009 Hi Bruce. for my trailer I bought an decrepit old caravan and with a chain saw made it into a flat bed trailer. I had a local boiler maker make wheel clamps with over centre clamps to hold the wheels down and put a $130 winch up front where the spare wheel had gone. Also a couple of ramps and had the wiring rationalised by an auto electrician. You might also contact the bushman as he has an all metal style for his supapup. Curandero
vk3eod Posted July 12, 2009 Posted July 12, 2009 Kit for sale Hi all. Well the crunch has come. My kit is up on ebay at a bargin price. If you know anyone that is interested in a kit, point them that way. they wont get a complete one any cheaper. Paul:crying:
Brett Posted September 16, 2009 Posted September 16, 2009 [ATTACH]8672.vB[/ATTACH]guys I was just wondering what your thoughts are about the dihedral,,,, I have set my wings up on props and are just about to drill the wing mount holes ,,,so far I have set it up at 1 , 1.5 , 1.75 and 2 degrees ,,, 2 degrees looks like a heck of a lot however , ,, what would be the lowest setting would anyone know so the flap levers (placed underneath) will clear the fuse? to get the angle I have string lined the wings at 10 foot and taken measurements from another string line from the root ribs,,, any thoughts on this method or is there a better way? Btw yes the plane is in my house ,,,need to drill these holes so I can put it back in the shed but the shed ain't quite big enough too do this important bit and I could never leave my baby out in the cold with no shelter for all this time hehe. in this photo the wings are set at 1.5
Guest swede Posted September 17, 2009 Posted September 17, 2009 Hi Brett, Can't help you as my pup made "upside down" 2 deg with the flap levers on top.... Regards SWEDE
kevinfrost Posted December 14, 2009 Posted December 14, 2009 There is another Aero Pup about to go on the register. Has anyone out there done wing loading tests (sand bags or the likes) and if so what loads did you take the wings up to. I'm asking for a friend who is not online and is not to sure how far to go. 1
Brett Posted August 11, 2010 Posted August 11, 2010 Yay ,,,Fabric kit came in the mail today ,,,, will be starting shortly hopefully.
Brett Posted August 19, 2011 Posted August 19, 2011 After about 4 yrs at home I finally took my Aeropup to the airport,,, still have quite a bit of work to do on it before it's inspected and flown but getting closer all the time,,,, 1
kevinfrost Posted August 21, 2011 Posted August 21, 2011 Hi Brett, looks good.:thumb_up: Lots of fun ahead. What method of trim are you using on the Aero Pup? I found we had to use a fairly strong spring to take the elevator load to aid the trim tag. Cheers, Frosty.
Brett Posted August 21, 2011 Posted August 21, 2011 I have just made the trim tab as per the instruction manual,,, exact sizes and all ,,, did you find it needed aid when set up for slow or fast flight?
