Disclamer - I HAVE NO COMMERCIAL INTEREST IN THIS AIRCRAFT.
Its versatility, the ventura is designed to fit into different market segments:
from the spacious two-seater with ample luggage area in the S-LSA category (600 kg MTOW) to the
three-seater version certified EASA VLA (750 kg MTOW) and at experimental four-seater (800 kg MTOW).
All metal construction and manufactured with cutting-edge industrial technologies, the ventura
is a high-wing plane that can accommodate engines with power ranging from 100 to 160 hp.
The ventura can approach for landing
is slow as 80 kph at maximum weight and with its high propeller clearance can operate from semi
prepared runways shorter than 250 meters with large margin of safety.
two, three or four seats plus bags depending what you want.
Fuel capacity 2 x 36 L + 6 L reserve / 20,6 US Gal
Extended range option 4 x 36 L + 6 L reserve / 9,6 US Gal
Baggage allowance 70 kg + 20 kg / 154 lbs + 44 lbs
MTOW (Kg) 600 kg (Maximum take off weight) 1320 lbs
Empty weight (Kg) 340 kg (Empty weight of standard configuration) 750 lbs
Useful load (Kg) 260 kg (Passenger, baggage and fuel) 574 lbs
Ventura ROTAX @ 600 kg 189kms 102 kts ROC 850
Ventura M09 @ 520 kg 210 113 1250
Ventura M09 @ 600 kg 208 112 1100
Ventura Lycoming @ 560 kg 225 121 1400
Ventura Lycoming @ 750 kg 222 120 1000
I see in the RAAus Ops Manual there is now a Category "D" which covers this MTOW. Not sure if the training for it is implemented yet.
