SSCBD Posted March 4, 2017 Posted March 4, 2017 Disclamer - I HAVE NO COMMERCIAL INTEREST IN THIS AIRCRAFT. Its versatility, the ventura is designed to fit into different market segments: from the spacious two-seater with ample luggage area in the S-LSA category (600 kg MTOW) to the three-seater version certified EASA VLA (750 kg MTOW) and at experimental four-seater (800 kg MTOW). All metal construction and manufactured with cutting-edge industrial technologies, the ventura is a high-wing plane that can accommodate engines with power ranging from 100 to 160 hp. The ventura can approach for landing is slow as 80 kph at maximum weight and with its high propeller clearance can operate from semi prepared runways shorter than 250 meters with large margin of safety. two, three or four seats plus bags depending what you want. Fuel capacity 2 x 36 L + 6 L reserve / 20,6 US Gal Extended range option 4 x 36 L + 6 L reserve / 9,6 US Gal Baggage allowance 70 kg + 20 kg / 154 lbs + 44 lbs MTOW (Kg) 600 kg (Maximum take off weight) 1320 lbs Empty weight (Kg) 340 kg (Empty weight of standard configuration) 750 lbs Useful load (Kg) 260 kg (Passenger, baggage and fuel) 574 lbs Ventura ROTAX @ 600 kg 189kms 102 kts ROC 850 Ventura M09 @ 520 kg 210 113 1250 Ventura M09 @ 600 kg 208 112 1100 Ventura Lycoming @ 560 kg 225 121 1400 Ventura Lycoming @ 750 kg 222 120 1000
Icarus Posted March 4, 2017 Posted March 4, 2017 Yes , will be interesting to see what build weights are in the future. Especially if RAA can go to 700kg or more. you could really pack some stuff in the rear seats area. As discussed in the thread below , 340 kg is probably no paint , and minimal avionics . http://www.recreationalflying.com/threads/ventura-4-seat.157174/page-1
Nightmare Posted March 4, 2017 Posted March 4, 2017 I see in the RAAus Ops Manual there is now a Category "D" which covers this MTOW. Not sure if the training for it is implemented yet.
