Wondering if anyone still makes engine mounts, cowls or FWF kits to suit the EA81 in a Zodiac 650. Or has any suggestions for other suitable parts, cheers Tim.
Hi Tim, I have a engine mount for an E81 to go into an zenith 701 might be the same or similar enough to alter.
Hi Tim,
Glad to see you're using a 'proper' engine !
My cowling came from Zenith and is listed for a Rotax 912. Depending on the mount, you may have to fibre glass two bulges for the rocker covers. I didn't need to but as I've used a Weber carb I had to put a bulge in the top instead.
Paul
Will depend on whether you use a redrive.
Engine hight will alter.
Huge power difference.
Chas
Will depend on whether you use a redrive.Engine hight will alter.
Chas
Looking at an Autoflight redrive, plus some of their other options like dual port heads, efi, tuned intake & exhaust.
  • 1 month later...
Sorry for the late reply Terry, are the 701 & 601/650 firewalls/engine mounts the same.
Hi akazia I doubt it
