Guest DonC Posted November 11, 2007 Posted November 11, 2007 Can anyone recommend good overnight stops between WA and Vic, after Forrest of course. Will be leaving Tuesday and booked in to Forrest Tues night. Thanks, Don
Guest peterf Posted November 12, 2007 Posted November 12, 2007 I take it you are flying. We stayed at Nullabor Roadhouse last year. They have a runway and expensive AVGAS; actually, pretty much everything there was expensive. It is in the middle of nowhere I guess. No complaints other than the price. I only have limited knowledge since that is the only place I've stayed around that area. http://planofile.com/map.html?pOfId=f971a012-ddf0-1106-bf32-28c16c5f824e Cheers
Guest High Plains Drifter Posted November 12, 2007 Posted November 12, 2007 Don, If you happen to be flying low enough on a direct track - Forrest to Caiguna, have a look for a park bench sitting in the midle of nowere. Aparently some helicopter borrowed one and dropped it off there HPD
Guest DonC Posted November 12, 2007 Posted November 12, 2007 Thanks fellas, but I will have enough fuel from Forrest to get well into SA
