allowera Posted November 10, 2007 Posted November 10, 2007 How many times have we heard this one? Living in a small country community and flying a Trike -quite a lot!! .Plus "peanut under a razorblade", "Sky-lifter" or the more suspicious "what are you doing up there?". Suggestion:- Fit a UHF Radio in addition to your VHF and set it to Channel 20. Make sure it is set to a maximum of threequarter volume of VHF[to be given priority at all times] and be aware that this channel is often used for Rural Fire Service [N.S.W.] and see how many locals respond. I have found that this interaction between myself and people on the ground has added a big [and positive] interest in recreational aviation in my locality. Small [1 watt or less] UHF Radios with VOX capability can be easily spliced [by your friendly local electronics wiz] to a standard Microlight Comms. System. During flight I have spoken to persons aged from 12 to 70+ and have been told of many others listening-in . One man even commented that "you should be able to charge for that - it's special" [Vicarious flight at it's best?] I suppose that this contravenes some flight rule, so could someone please advise me as to whether I should stop or not ? Thanks. Man's oldest dream is flight, His oldest fascination is fire, oldest fear is becoming food. [Watch your EGT on climbout or it may bite you]
blueshed Posted November 10, 2007 Posted November 10, 2007 Hi allowera Where is Tanja? Somewhere in NSW at a guess! I don't think there is a problem with using a UHF while flying, even have my telepnone and MP3 hooked in as well! I believe you are not meant to interfer with aircraft comms, as you have it spliced in and you can still hear VHF, should be of no problem. Cheers Guy
allowera Posted November 11, 2007 Author Posted November 11, 2007 Thanks Guy , Tanja is located far south coastal NSW approx 16 Nm north of YMER. An MP3, there's a thought. I could broadcast that out through the UHF as well. Hmmmm. I wonder how the local cocky's would react to heavy metal??? On second thoughts, perhaps not. Happy landings, Paul.
