It looks as if this is a return to the Cessna type wing, which has drag from the wing / strut / fuselage connections, but the strut looks as if it may deliver lift.
Back to the biplane?
I wonder where they got those weights from. The wing looks to be a very high proportion of gross weight. maybe it includes the engines and fuel.
They obviously need the strut because the wing is so thin that they can't get sufficient strength with a cantilever. Thinner wing = less fuel capacity, but that's OK if you are saving fuel. I bet a lot of work went into the strut-to-wing joint. Probably not trying to get lift off the strut so much as reduce drag.
