In my new plane I have a dash mounted avmap ekp1v, when I press go to and select airports I cannot get a list of airports, I know it's there because I found it once before but can't remember how, the manual I down loaded isn't much help either, I only want to select an airport as a destination as a backup for oz runways can somebody explain it to me in easy steps thanks Keith.
Press "Page" to get the list of nearest airfields, scroll to highlight the one you require, then press "GoTo".
Not the most intuitive setup but once you are used to it it is not a bad unit.
Cheers!
Thanks Mick had all ready worked that one out but need to find airfields further away than the ones listed on page,
When I press go to and select airports I get the information box of an airport, I need to get out of this and back to the list of airports
