JEM Posted May 31, 2016 Posted May 31, 2016 Just received new email from Jabiru To the Jabiru Fleet, Updates – Keep up with the latest information Revision 9 of the Jabiru Overhaul Manual (JEM0001-9) is now available to download from the Jabiru website at the following link:- http://jabiru.net.au/Manuals/Engine/JEM0001-9_Overhaul_Manual.pdf The updates in the revised manual are outlined below :- Oil specification changed (was MIL-L-22851 now obsolete) to SAE J-1899 Changes to Torque setting table made (Table 9) Additions to Top End Overhaul Mandatory replacement item table (section 5.3) Additions to Mandatory Replacement Parts Table (section 12.1) Add Crankshaft friction test procedure (section 4.4.2) Update to part history tables (section 13) Remove modified circlip pliars from Figure 21 Clarify distributor shaft procedure (section 7.8.6) Remove alternator dimension from Figure 144 Add laminated pole plates (Figure 146) ‘Generic’ Torque settings removed (Table 9) Note to install stud bolts with Loctite 263 added, no longer 620 (section 7.2.1) Fuel pump assembly revision (section 7.7.2) Add part in trouble shooting (section 8.5) regarding zero leak-downs when cold Revise rocker bush installation (section 5.11.8 and Figure 98) Kind Regards Leigh Cooper Aircraft Services & Registration JABIRU AIRCRAFT PTY LTD PO Box 5792 Bundaberg West Qld 4670 Ph: 07 41551778 Fax: 07 41552669 Email: [email protected] www.jabiru.net.au www.facebook.com/JabiruAircraft 1 3
