  • 4 weeks later...
The Sloper has splash fed bearings, Chev used it up until 1953.
White metal bearing on the crank and 4 shims in the conrods to set up the gap.
Last forever, l have dropped the sump in the car to remove a shim on a hammering bearing to fix it.
We had it on a dyno a couple of years ago 29hp at the rear wheels, exactley what the manual said.
Not bad for a 76 year old.
regards Bruce
