bruce01 Posted October 6, 2007 Posted October 6, 2007 Hi Guys, I'm having trouble with the temp guage on 582 on my trike. All's well at warm up and taxi. Soon after I'm airborne it goes dead. Land, kill engine, ignition off, temp guage works. Restart engine, temp not working. Went home and looked at wiring diagram. Next day after touching nothing, same thing. All other guages are fine. Any Ideas? A mechanical friend suggested fitting a capillary guage instead. Any thoughts, ideas would be appreciated. Bruce:)
brilin_air Posted October 6, 2007 Posted October 6, 2007 Hi Bruce, can you reproduce the problem by wriggling the wires from the sender to the gauge, check all along the whole length of the wire,and is there any fluctuations in the gauge reading while you are taxiing, I would be looking at the connections at the sender for a good tight clean contact, and if you can get the problem on the ground, earth the sender wire to see if the gauge moves, if it does not then I might suspect the gauge as being faulty, if it does move then I would suspect the sender unit Brian
