Yesterday and today fast taxi test getting ready to fly and i noticed rough running on the mag check ,
Im using iridium plugs and didn't check the gaps , they were about 028 thou ,
First time I've used iridium plugs NKG , and thought the gap looked excessive ,
Regapped to 022 tho . all good .
Apparantly they are supposed to be like that ??
gapping them its VERY easy to break electrode Im told
I have dropped one before and fixed no probs
On the nkg site , they say to gap to manufactures spec .
They say the large gap if for performance ignition systems and to add 004 tho per 50hp over standard ,
Like wise reduced gap to jab specs .
Anybody have experience with them in a 582?
I tried them because an engine I bought came with a spare set, I really didn't notice any improvement. They appeared to perform exactly as standard ones, they seemed to collect buildup at the same rate too.
I fouled the plug on my Yamaha WR426 , which was quite common with the pumper carb. I switched to a Iridium plug and I never had a problem after that. They are expensive and I have heard stories of the electrode breaking off, but I have never had a problem with them.
I never adjusted the gap but as mentioned by Avocet, NGK do recommend gap adjustment.
Who would have thought to read instructions!!!
