Hi all
I am wondering if any fellow forum users may know where I could find a suitable throttle lever which is electronic, to control an electronic throttle body on a 2004 Subaru EZ30D "R".
I am building up an the above engine with a LINK ECU from our NZ neighbours and installing it into a Zenith CH-801.
If you would need some more info please let me know.
If you would like to see a log of my build which also has a bit of info on my engine so far check out my blog,
www.zenithch801buildlog.blogspot.com.au
Cheers,
Pete
You are better off looking at a accelerator pedal from late model car. Must make sure it's compatible with your ecu and throttle body.
Yes. I have a Subaru acc pedal however i was hoping to find something that does not have a return to zero spring. If possible, something that i can mount without modifying. But as a last resort i do have the subaru pedal.
The ECU i have has a separate throttle controller which hard wires to the ECU. Acc pedal input goes to ECU then the controller drives the throttle butterfly.
Thanks
I have also considered replacing the throttle body with a manual system that has a throttle position sensor but not sure how that would affect the ECU maps? Unfortunately i only have very limited ECU knowledge so happy to receive any advice at this stage.
Thanks
