Vev Posted November 9, 2013 Author Posted November 9, 2013 jtm001-2 section 6.19 look for manual on Jabiru websitehave modified several aircraft to eliminate tyre wear I fitted machine shims and set camber almost vertical with full fuel aircraft operating off hard surface and now do not have to rotate tyres every 100hrs to promote even wear Mick, Thanks again. Found it ... Under Special Instruction in section 2, 4.18 page 49 ... Would have been easier to find if it had of been included in the undercarriage section and not a separate Special Instruction! Turbo got it spot on with his suggested method Thanks for the help guys ... I'll have play and see how I go. Cheers Vev
