Tail Wheel
Guest marbrody
Can any one help me with a Tail wheel solution?
I go through these little things about every 3 weeks, I need i think an inflatable one or a fairly wide softer rubber one that does not dig in to the soil.
Does anyone know who may supply a tail wheel that has good grip and vibration absortion factors.
Guest ozzie
have a talk to Tony From thruster support group for the type they are using now. ozzie
Guest Deano
This sounds really funny... But i was a supermarket manager and had an endless supply of shopping trolly wheels.. And they were a perfect fit!! Lasted well too.
Glenn
Guest micgrace
Hi Glenn
Funny you should say that about shopping trolley wheels. A few simple aircraft plans out of the USA actually suggest the use of one as a tailwheel. (and wheelbarrow tyres for the mains, yuk!)
I'd be somewhat heisatant to use one, but they do work. Actually probably a bit stronger in reality than the certified one.
The Drifter I originally learnt in when through the things with regularity. Grass strip, mud, potholes.
Seen something in Super Cheap Auto one day (pneumatic caster wheel) that could easily be used but you wouldneed to make up a bracket first though and the thing even had needle roller bearings.
Micgrace :)
and shopping trolley wheels are so cheap! just $1 for 4 of them! and you also get a free wire steel storage box with them!
yeah...and 6 months free meals and accommodation if you get caught!Bruce
006_laugh.gif.0f7b82c13a0ec29502c5fb56c616f069.gif 011_clap.gif.c796ec930025ef6b94efb6b089d30b16.gif
  • 1 month later...
Guest marbrody
Thank you to all who came up with ideas, I did try the shopping trolley wheel but only got two flights out of it before it disinigrated.
Wayne Fisher has I think solved the problem by supplying me with a second hand strut braced drifter tail wheel, this seems very robust and i believe will do the job.
Thank you again for your input
