Hi Guys,
The above have been pretty hard to find. What I need is empty weight, MTOW, min and max fuel. Are there individual seat limits?
Kevin
Hey Big Kev.
MTOW 520 kg
Max Baggage 10kg
Minimum single pilot weight 55kg
VNE 93Kts
VNO 86Kts
VA 80Kts
empty weight 321.9 or 326.9 depending on accessories
these weights where from my Gazelle.
hope this helps
Hey Big Kev.MTOW 520 kg
Max Baggage 10kg
VNE 93Kts
VNO 86Kts
VA 80Kts
hope this helps
VA 80?
Can it actually go this fast at a constant height? I remember when I was learning to fly in one, we had 60-65 cruise. And it didn't get much better.
My Gazelle cruises at 75 knt at 5000rpm and will cruise at 80 knt at flat out.
Both figures backed up by GPS readings
John
Guest brentc
With the original timber prop they were only really good for around 70-75 knots at best. Anything better would come from a carbon / glass prop.
Mine was about a 72 knot machine and was pretty consistent with the 2 blade timber.
At a few more RPM I could get nearer 80.
Are those figures indicated or true? Because the ones I flew (timber prop) had no hope of that speed indicated, up a bit higher they would have trued it.
Can't remember the RPM settings.
Hi Kev, If speed isn't an important criteria, how about a Lightwing (tail-dragger). I haven't flown one but have looked into the clubs example and the cockpit looks pretty roomy when compared to the Jabiru. Doug
PS Kev, the Blackburn Beverleys is in no way a dig at your supposed size :big_grin:
Heh heh...... might be as large but sure not as damned ugly!
May be like your av- sleek and powerful.........
Big kev
:confused:
Looked at a Skyfox and Gazelle today. Must have looked decidedly funny, but I did sit in it. No point in going further, and thanks to Graham for his efforts.
Have to look at a Lightwing, but the field appears to be narrowing fast!
Kevin
