Here is a link to check if your engine is affected by this AD.
http://www.rotax-aircraft-engines.com/portaldata/5/dokus/d05094.pdf
I was unable to download the one on the CASA website.
Fortunately my engines serial # is not included & hopefully this will be the case for everyone here in Australia at least.
Interesting that there may be the possibility of some financial support from Rotax. I would think a free crankshaft would be a good place to start...........
Greetings all,
As some of you may be aware, Rotax have yesterday released an Alert service bulletin in regards to a possible crack that could occur on some 912-914 series crankshafts.
The engine serial numbers affected are listed in the Rotax service bulletin, however for some reason the EASA AD lists ALL 912 and 914 engines as being affected, this is not the case.
For ease of looking, I have attached to this e mail an Excel file which lists ALL the engines affected by there serial number and also the official Rotax alert service bulletin.
No engines sold by Bert Flood Imports are affected, however there may be some factory built aircraft, or engines supplied with overseas kits imported into Australia that may be affected, so I suggest that people check there engine serial number with the list attached.
ALL the engines affected were built at Rotax during the period of October / November 2010
We are aware of only 3 engines in our distribution area that are in fact affected by this service bulletin, and I will be contacting these people directly.
If you require any further information, please do not hesitate to contact me.
Best Regards
Wal
Bert Flood Imports Pty Ltd
17 – 18 Chris Drive
Lilydale Victoria 3140
Australia
Ph +61 3 9735 5655
Fax +61 3 9735 5699
Email [email protected]
I got this the other day, but still check I think
Cheers scotty
Hi Scotty,
Nice to hear it may be low impact in Oz.
We have 4 rotax powered Gazelles in our school and was wondering what the impact may be.
Btw ... cant see the spread sheet you mentioned??
Vev
Crankshaft S/N
Engine S/N Engine Type
40426 4410884 912 A2
40424 4410885 912 A2
40422 4410887 912 A3
40463 4412984 912 F3
40462 4412985 912 F3
40236 4420965 914 F2
40349 4420966 914 F2
40478 4420967 914 F3
40477 4420968 914 F3
40469 4420969 914 F2
40464 4420970 914 F2
40432 4420972 914 F2
40435 4420973 914 F2
40436 4420974 914 F2
40440 4420975 914 F2
40438 4420976 914 F2
40466 4420977 914 F2
40439 4420978 914 F2
40256 4924044 912 S3
40257 4924045 912 S3
40259 4924046 912 S3
40264 4924047 912 S3
40265 4924048 912 S3
40267 4924049 912 S3
40329 4924050 912 S2
40337 4924051 912 S2
40335 4924052 912 S3
40310 4924053 912 S3
40300 4924054 912 S2
40302 4924056 912 S2
40303 4924058 912 S2
40461 4924064 912 S2
40456 4924065 912 S2
40455 4924066 912 S2
40453 4924067 912 S2
40450 4924068 912 S2
40447 4924070 912 S3
40446 4924071 912 S3
40444 4924072 912 S3
40443 4924073 912 S3
40442 4924074 912 S3
40441 4924075 912 S3
40507 4924076 912 S3
40480 4924077 912 S2
40358 4924081 912 S2
40359 4924082 912 S2
40373 4924083 912 S3
40488 4924084 912 S3
40361 4924086 912 S3
40298 6770159 912 UL2
40294 6770160 912 UL2
40293 6770161 912 UL2
40323 6770162 912 UL2
40319 6770163 912 UL2
40460 6770164 912 UL2
40459 6770165 912 UL2
40458 6770166 912 UL2
40457 6770167 912 UL2
40454 6770168 912 UL2
40452 6770169 912 UL2
40451 6770170 912 UL2
40448 6770171 912 UL2
40479 6770172 912 UL2
40476 6770173 912 UL2
40475 6770174 912 UL2
40474 6770175 912 UL2
40473 6770176 912 UL2
40366 6770184 912 UL2
40304 6774151 914 UL-LB2
40306 6774152 914 UL-LB2
40301 6774153 914 UL-LB2
40305 6774154 914 UL-LB2
40299 6774155 914 UL-LB2
40316 6774156 914 UL-LB2
40309 6774157 914 UL-LB2
40314 6774158 914 UL-LB2
40308 6774159 914 UL-LB2
40307 6774160 914 UL-LB2
40295 6774165 914 UL-LB2
40251 6774166 914 UL-LB2
40325 6774168 914 UL-LB2
40336 6774169 914 UL-LB2
40333 6774170 914 UL-LB2
40332 6774171 914 UL-LB2
40315 6774176 914 UL2
40339 6774177 914 UL2
40340 6774178 914 UL2
40342 6774179 914 UL2
40343 6774180 914 UL2
40345 6774181 914 UL2
40346 6774182 914 UL2
40347 6774183 914 UL2
40250 6774184 914 UL-LB2
40351 6774185 914 UL-LB2
40296 6774186 914 UL-LB2
40352 6774187 914 UL-LB2
40312 6774188 914 UL-LB2
40311 6774189 914 UL-LB2
40326 6774190 914 UL-LB2
40322 6774191 914 UL-LB2
40327 6774192 914 UL-LB2
40334 6774193 914 UL-LB2
40421 6774199 914 UL-LB2
40419 6774200 914 UL-LB2
40417 6774201 914 UL-LB2
40414 6774202 914 UL-LB2
40418 6774203 914 UL-LB2
40415 6774204 914 UL-LB2
40413 6774205 914 UL-LB2
40412 6774206 914 UL-LB2
40408 6774207 914 UL-LB2
40409 6774208 914 UL-LB2
40472 6774209 914 UL2
40468 6774210 914 UL2
40471 6774211 914 UL2
40467 6774212 914 UL2
40470 6774213 914 UL2
40246 6774220 914 UL-LB2
40235 6777492 912 ULS2
40233 6777493 912 ULS2
40240 6777494 912 ULS2
40239 6777495 912 ULS2
40234 6777496 912 ULS2
40244 6777497 912 ULS2
40243 6777498 912 ULS2
40237 6777499 912 ULS2
40252 6777500 912 ULS2
40247 6777501 912 ULS2
40253 6777502 912 ULS2
40255 6777503 912 ULS2
40254 6777504 912 ULS2
40249 6777505 912 ULS2
40263 6777514 912 ULSFR2
40331 6777526 912 ULS2
40330 6777527 912 ULSFR2
40321 6777528 912 ULS2
40317 6777529 912 ULS2
40313 6777530 912 ULS2
40318 6777531 912 ULS2
40338 6777532 912 ULS2
40320 6777533 912 ULS2
40341 6777534 912 ULS2
40348 6777535 912 ULS2
40344 6777536 912 ULS2
40367 6777537 912 ULS2
40324 6777538 912 ULS2
40368 6777539 912 ULS2
40369 6777540 912 ULS2
40370 6777541 912 ULS2
40371 6777542 912 ULS2
40357 6777544 912 ULS2
40360 6777545 912 ULS2
40372 6777546 912 ULS2
40363 6777547 912 ULS2
40374 6777563 912 ULS2
40365 6777564 912 ULS2
40258 6777565 912 ULS2
40260 6777566 912 ULS2
40261 6777567 912 ULS2
40262 6777568 912 ULS2
40266 6777569 912 ULS2
40297 6777576 912 ULS2
40506 6777577 912 ULS2
40505 6777578 912 ULS2
40504 6777579 912 ULS2
40500 6777580 912 ULS2
40503 6777581 912 ULS2
40501 6777582 912 ULS2
40499 6777583 912 ULS2
40498 6777584 912 ULS2
40495 6777585 912 ULS2
40491 6777586 912 ULS2
40484 6777587 912 ULS2
40490 6777588 912 ULS2
40489 6777589 912 ULS2
40487 6777590 912 ULS2
40483 6777591 912 ULS2
40482 6777592 912 ULS2
40481 6777593 912 ULS2
40497 6777594 912 ULS2
40431 6777596 912 ULS2
40427 6777609 912 ULS2
40496 6777610 912 ULS2
40350 6777624 912 ULS2
40354 6777625 912 ULS2
40353 6777626 912 ULS2
40355 6777627 912 ULS2
40356 6777628 912 ULS2
40362 6777630 912 ULS2
40364 6777631 912 ULS2
40410 6777634 912 ULS2
40411 6777635 912 ULS2
40416 6777636 912 ULS2
40420 6777637 912 ULS2
40492 6777638 912 ULS2
40425 6777639 912 ULS2
40493 6777640 912 ULS2
40494 6777641 912 ULS2
40502 6777642 912 ULS2
40328 6777667 912 ULS2
40485 6777668 912 ULS2
40465 6777686 912 ULS2
40449 6777688 912 ULS2
40437 6777689 912 ULS2
40433 6777690 912 ULS2
Vev This is the list of affected engines I got in the email sent on to me. Hope yours are not on the list and yes David it is good to see a bit of support from at least one mob.
Cheers Scotty
Are they running 4 Gazelles down there these days Vev? Must be picking up!
Thx Scotty,
This list is very helpful.
av8,
Yes mate we are running 4 of them now and have a couple of C162 inbound as well ... RAA training is going great guns.
Vev
