Guest brentc Posted July 9, 2007 Posted July 9, 2007 Found this tonight. I have no idea what happened to the pilot of this thing, however it must have hurt, a lot.
eastmeg2 Posted July 10, 2007 Posted July 10, 2007 Well, that's Nanolight Trike for you. I went forward to the next video of a crash due to EFATO. . . the motors they use leave a lot to be desired. They'd be a lot better off using the Rotax-288 single cylinder 28hp motor, assuming that's had the same engineering development as the early 503's & 582's. They also don't seem to have been trained to keep landing areas within glide distance . . . Rgds, Glen
Guest disperse Posted July 10, 2007 Posted July 10, 2007 i wonder if thats the same one that had the first crash......might of loosened the shute
Guest Fred Bear Posted July 10, 2007 Posted July 10, 2007 Clowns. Look at how they fly. One day they will make the final cut of their videos.
rick-p Posted July 10, 2007 Posted July 10, 2007 Darren, those BRS chutes can be a blessing but also a big danger in certain circumstances. Mate of mine had a heavy hit in a Quicksilver and it broke and seperated the airframe at a point where the cable for firing the rocket motor was routed and it cause the cable to pull tight and fire of the rocket. End result, the instructor received a severely burnt arm. Close call because a few inches to the right and he could have lost his head. I think my mates bumb got scorched. Regards, Rick
