Thruster87 Posted June 24, 2007 Posted June 24, 2007 Would there be any advantage in going with a 3 blade prop + C box on a 503 over the sweetapple 2 blade and the B box ? Cheers
Thruster87 Posted June 25, 2007 Author Posted June 25, 2007 Just got off the phone with Aerofibre and they recommend a 68" 3 blade at 13 deg.pitch on a 503 with a 'C' box. at 3:1 Cheers
Guest TOSGcentral Posted June 25, 2007 Posted June 25, 2007 A B or C box will give about equal results but the C has the major advatage of the shock absorbing dougnut in the drive train. Both props will work well. However the Brolga will give you a much smoother engine and probably more thrust Tony
