Can anyone tell me the correct internal diameter fuel hose to use on 912 installation ? I am talking about from the fuel selector to the gascolator and electrical fuel pump etc.
Guest Maj Millard
Rotax specifies a minimum of 9ml internal diameter (ID) ,most hoses tend to be about 10 ml ID which is fine.................Maj...
Guest Maj Millard
Oh sorry, the above was for oil lines, fuel lines ar either 1/4" ID or 5/16" ID or whatever the Ml equivalent is. Mostly they are 5/16".
Personally I don't buy fuel line unless it has USA written on it, as it just seems to last longer and therefore be safer in the long run. Especially if the lines are not accessible for a long time like in a wing, or under a floor etc......Some of the lesser fuel hose these days is just scary.........Maj...024_cool.gif.7a88a3168ebd868f5549631161e2b369.gif
Thank you.
Oh sorry, the above was for oil lines, fuel lines ar either 1/4" ID or 5/16" ID or whatever the Ml equivalent is. Mostly they are 5/16".Personally I don't buy fuel line unless it has USA written on it, as it just seems to last longer and therefore be safer in the long run. Especially if the lines are not accessible for a long time like in a wing, or under a floor etc......Some of the lesser fuel hose these days is just scary.........Maj...024_cool.gif.7a88a3168ebd868f5549631161e2b369.gif
