Dose anyone know how to set up weigth & Balance in Ozrunway for a Australia lightwing Gr 582 ?
Doug
It is fairly straight forward if you flight manual has W & B information i.e. arms for seating, fuel and cargo area, COG etc.
Without this info you would have to weigh and calulate this info - LSAs have this info, but I am not aware if all RAA aircraft have this info in their flight manual??????
The info is relevant to each aircraft and not an aircraft type. Builders might be able to assisst you there, my knowledge is limited to useing the supplied info relevant to flying a particular aircraft.
Two aircraft of the same type can differ with the location of the battery for example.
Ross my have more info re Lightwings..
